Forage Farmer
New User
Have a couple pf Questions as a go through an Oliver 1800 B series, 1963 S/N #134298
First...Anyone know of place to find Marvel-Schebler USX 32-1 Pump Discharge Jets...P/N 156 665-A (M-S P/N#49-526)? Alternatives aso an option if you now of any.
I do have a TSX carb off of a 1962B series that I am going to rebuild to get running, but would like to keep original if possible.
Second...The water pump on this tractor is a Cast number 221360 (P/N# 156 060-AS)
Question is, can you use a Cast number 221560 (P/N# 157 069-AS) if you change the thermostat housing to run the by-pass hose. The cast number 221560 pumps are a dime a dozen, and 221360 pumps are hard to find.
Just curious. I ordered all the parts separately to rebuild the 221360 pump, but thinking it looked possible and am curious.
This tractor seems to fall into some twilight zone of serial numbers that are slightly different out of the factory.
Thank you for the assistance.
Jim
Jim
