ajdeereman
I have inherited a 77 Oliver that has not run for 22 years. I got it running on wd40 then it started running on gas but smoked like crazy at idle and gas would run out the carb when shut off. I took the carb off and found that the needle tip was gone. I then sprayed carb clean and air through all the ports and but back together. I ha e the idle at 1 turn and load at 1 1/2 turns out. I put the carb back on and tried to start it and can not get to start on gas. I put a petcock in the bowl and have gas at the bowl as it runs out petcock but when you try to start it it will not start and gas stops running out the petcock. Have tried with petcock closed also. I can get it to run on wd40 and carb cleaner but when you stop spraying it dies. Any thoughts.
