cat 3 lift arm balls
TP in IA
where can I get cat3 lift arm balls to cat2 balls as my 2-105 has the cat 3 lift arms, besides from agco Thanks
Don?t buy the cheap local farm store replicas, they are soft and you can literally wear out a set in a day. The last thing you want on a hard pull is to have a ball slip out of the lift arm. The end result is severely damaged tillage equipment and tractor arms. It will ruin a good day and will remove the smile that you had when you bought 2 balls for $15.
This has happened to a lot of farmers and I was lucky by learning from them, 10 to 12 years ago I spent $65 on a set of AGCO balls and to date they show no wear.
we sell both they are virtually identical call link_disallowed days ask for larry--we have agco and nos either----only difference price
