Update, I tried to adjust the pto clutch but nothing I did, did anything. I guess it's looking like a spit is in my future. So I
need to get to using the tractor so I remounted that remote back on same as before. Ran the tractor but still the three point
isn't working. I spent a fair bit of time on it today with nothing to show for it. Can't figure out what my issue is or what I
did to cause the problem. I though mounting the remote back on would solve the issue but it did not.
I have another question on the hydraulic. The fill is the cap with the dip stick right? How much goes in this? Grade? The other
cap is the transmission is it not? How much there and what grade? I see nothing on the cap with the stick and peering in the
hole I can see the bottom. I need oil but can't figure out where it all went. I didn't leak out that kind of fluid out the
remote holes I know that. I leaked maybe a teaspoon full. Nothing around the tractor either. I also see nothing in the other cap
either. There is a metal piece right under that cap. I hope there isn't an issue with running out and damaging the three point
pump. What do I check now? I'm stumped.
