1855 bigger rubber
snowriderz
New User
I just bought an 1855 with wore out 18.6 x 34 rears and want to run 20.8 x 38. And has skinny fronts what do I need for 11x16 fronts can I use the rims I have or what size do i need
I had 11LX15 4 ribs on the front of my 1800. Put them on there so they did not tear up the hay field.
If you are going to put a loader on it make sure you get the rims with the heavy center, not plain old wagon rims. Wagon rim centers are not heavy enough and they break out.
For the rear, you need cast center and rims.   Cast center will have the number 166 217-A cast into it.   Those should be easy to find as it was used on tractors beginning with the 50 series, 1650 and larger models.
I'd be careful about turning rims out there too far. Unless everything is super tight in the front end,it's likely to shimmy like crazy.
