1555 Oliver hydraulic cooler
Bought a 1555 Oliver in a million pieces. It has the hyd cooler in front of radiator that has the 4 outlets (part# 30-3001385 sub 30-3225704) This tractor has a straight drive no over/under. Did they just not use half of the cooler? Looks like there never was a second set of line going up there. It appears tractor was built this way.
I would say yes as my 1555 oil cooler had lines to Hydra Power drive. Still have the cooler and the Hydra Power but tractor was repowered with 1650 engine and water cooled Hydra Power. I have a couple pics of cooler and where the lines go into the Hydra Power drive.
My 1550 just uses a bent tube with fins in front of the radiator for an oil cooler. The 1600 does too. The HydraPower cooler is on the HydraPower unit itself on both. You could just cap the inlet and outlet side of the cooler that you have if it's just direct drive.
