My super 77 will not start. I just finished painting it and have it all back together. The motor will crank over well but will not start. Here is what I have tested;
-I have cleaned and checked the float on the carb multiple times, everything works good.
-I put new fuel in the tank, the tank is over half full with fuel
-I put in plugs, rotor, wires and points in the tractor
-I have good spark at all plugs, all plug wires are going to the proper cylinders
-My points open and close as they should
-I have traced all wires and have power at the proper locations
After I crank the motor over for a bit, I pull the plugs out and they do have some gas on them. I tried taking out a could of plugs and poured gas down them. It seemed like it wanted to fire but it didn't. My throttle and choke butterflies are both opening and closing properly. I do not currently have an inline fuel filter in place because I wanted to make sure that was not my issue and restricting fuel flow. Any suggestions or help would be great. Thanks
