1550 and 1650 use the same transmission?
The 1650 has a lubrication system with the pump run off of the back of the countershaft. 1550 spur gear transmission do not require lube system, Thus the 1650 has a filter on the LH side of the transmission where the 1550 does not.
You're lucky if it's not the late one. They're the same as a 1555. Harder to find from my experience looking for one.
