TractorLinks.com
Show Parts for Model:
1550 and 1650 use the same transmission?
todd d
05-19-2017 19:58:44
Are they the same units?
Todd
Mike(NEOhio)
05-20-2017 14:30:35
 Re: 1550 and 1650 use the same transmission? in reply to todd d, 05-19-2017 19:58:44
Do you have a broken shifter rail? Right hand one broke on mine last summer. Got a used one from Smitty's.
rrlund
05-20-2017 15:55:52
 Re: 1550 and 1650 use the same transmission? in reply to Mike(NEOhio), 05-20-2017 14:30:35
You're lucky if it's not the late one. They're the same as a 1555. Harder to find from my experience looking for one.
Mike(NEOhio)
05-20-2017 16:44:49
 Re: 1550 and 1650 use the same transmission? in reply to rrlund, 05-20-2017 15:55:52
Mine was the early with the neutral switch at the back end. Switch bracket was broke off, of course. Later one is the same but shorter at the back end.
B A Star
05-19-2017 20:57:25
The 1650 has a lubrication system with the pump run off of the back of the countershaft. 1550 spur gear transmission do not require lube system, Thus the 1650 has a filter on the LH side of the transmission where the 1550 does not.
todd d
05-20-2017 09:47:58
 Re: 1550 and 1650 use the same transmission? in reply to B A Star, 05-19-2017 20:57:25
Does the 1650 and 1550 trans use the same style shifter rails??
J. Schwiebert
05-20-2017 10:30:42
 Re: 1550 and 1650 use the same transmission? in reply to todd d, 05-20-2017 09:47:58
Do you mean will they interchange? The answer is NO. You are shifting collars in the 1650 and gears in the 1550.
todd d
05-20-2017 11:40:45
 Re: 1550 and 1650 use the same transmission? in reply to J. Schwiebert, 05-20-2017 10:30:42
Darn it. Thanks mr J
todd d
05-20-2017 07:14:04
Thanks all
J. Schwiebert
05-19-2017 20:16:00
NO. The 1650 is a helical gear transmission, the 1550 is a spur gear transmission. The casting is the same
