Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Oil Pressure
Kevint1564
05-19-2017 08:25:16
I have a 1750 Oliver with a 310 Diesel. I am noticing that my oil pressure drops under 20 psi after engine heats up. Engine runs well with plenty of power. I currently run 15w40 Rotella T oil. Should I change the viscosity?
riverrunner
05-21-2017 16:54:39
 Re: Oil Pressure in reply to Kevint1564, 05-19-2017 08:25:16
I have had a 1750 since the early 80's. The oil pressure is the same as yours, starts out just under 40,warms up and runs all day just under 20. Great tractor.
Kell
05-19-2017 15:44:11
How far under 20? And by heated up, do you mean warm or working/load hot? I run Shell 15w40 in my 1750, and totally cold it's around 60-70psi. Warmed up = 40-50, and working-hot it's around 30. Normal op range for working full load hot is supposed to be 20-30.
J. Schwiebert
05-19-2017 10:38:17
20 pounds is at what engine RPM? How much oil pressure do you have when engine operating temperature is cold? Does your block has a place for an engine oil cooler?
jasinpa
06-04-2017 06:49:10
 Re: Oil Pressure in reply to J. Schwiebert, 05-19-2017 10:38:17
ive been told that using 15w-40 is not a good idea in these engines the factory used & book shows straight 30w , shell makes a rotella 30w diesel oil , thats what i use w/ 1 quart of lucas added in my 310-t , 15-40 is thinner then 30w
