coupler chain connector link
Does anyone know if there is a source for just the connector link? My chain came apart and I lost the connector, the chain is fine. Hate to have to buy complete new chain. Would like to have one for a spare. Thanks
Should be able to get it at a good power transmission store such as TEC industrial, I got chain there years ago and they had coupler links separate.
Pete
I would try Agpartsfirst or Maibachs. Its expensive for a connector $17-20. Make sure the one you get has one cotter pin to go thru both pins. If not pins will spin around and eventually it will cut thru and break. You were lucky, when my friends chain came off his 1750 it cut thru all the power steering lines and they are a special inverted flare.
