Well we installed a new hydraulic pump last summer, flushed system twice and replaced filter. Hydraulics never worked better. Stored the tractor over winter, disconnected battery and left it sit. Fired it up yesterday and hooked up round baler and pulled both outside to clean baler. Found out 3 point hitch(tractor has external lift cylinders on the three point) would not move-stuck in high position. Then discovered that rear door on baler would barely open, seems like pressure is low. How do I get 3 point to work- bleed cylinders or pull on arms with skid loader or another tractor? I tried prying on the cylinders with the motor running and could not get cylinders to retract. Would the three point being stuck in the high position cause a low pressure problem with slave cylinders? Power steering, brakes and PTO seem to be fine and system is full of fluid. Any advice would be appreciated. Thanks.
