2150 headlights
Finally found the 2 hole light bezels for my fender fuel tanks. My tractor had a cab on it so no lights in the fender fuel tanks. Does anyone know what the right light for one of the last 2150's built? The ones with the metal ring holding the light bulb in or the ones with the rubber ring holding the bulbs in?
From everything I see, it would be the rubber ones. The metal rings were used on the 00 series and early 50's. I think it may have switched sometime in 67 but not sure.
Larry,
I'm not sure which is right for late 50 series. But I have replaced a few with led's. They are not cheap, and they are not 100% original but they look very close. Only a very detail oriented person would pick them out. But they are as bright as the sun. I found some to put in the original buckets on a super 88 I just finished. Looks original in the old buckets, but as bright as any new tractor has.
Josh
