I posted earlier about issues with the staring system on a 1650. Did what rvirgilKS said, rechecked wiring and found a couple of crossed wires. Got it to start but sometimes the switch doesn't do anything then other times it will hit. Usually when it turns over it does so really slow, like it's not getting full voltage.
Got it to start once and found out the starter failed to disengage. Smacked the end and it dropped out. Is it possible that accidently leaving the key on fried the points and condenser and that is what is causing the problem. My multimeter died a bit ago and I haven't bought a new one yet so I'm going by a test light. Does the ignition wire have current running through it whenever the key is on or only when you are actually starting it?
