Having a perplexing problem on my 4-150 with the 3208. The thing is randomly getting air in the fuel supply line. May run for 2 hours and not do it, may run for 200 feet and do it 2 or 3 times in a row and it seems to do it worse as the weather gets warmer. Tractor will be running along fine then all of the sudden it will become gutless and I have to shut it down, bleed the fuel system out and it will take off and go again. All the fuel lines from the tank to the divider block on the back of the engine are brand new. The steel line from the divider block to the fuel filter was cleaned out and checked, fuel primer pump is brand new, fuel filter is brand new and the fuel tank is clear full. Im 99% positive that its not the injector pump because the thing runs to good and to strong. Now the motor does run on the really warm side. Im going to get a new thermostat for it tomorrow since the radiator and water pump are already brand new. Im thinking that it cant be a coincidence that the thing does it when the motor gets warmed up, and gets even worse when its 70+ degrees outside. I didnt think it was, but is it possible for a diesel to vapor lock because that sure is what it seems like its doing?
