Oil pressure line
centralilbaler
I have an 88 with a pin hole in the oil pressure line to the guage. Is this something that could be fixed or should i just replace the line?
You might be able to take it off and braze it if you can get all the oil out and keep from burning the hole even bigger.
(quoted from post at 07:56:58 04/13/17) I have an 88 with a pin hole in the oil pressure line to the guage. Is this something that could be fixed or should i just replace the line?
You may be able to flare the ends and splice it.
I just go to the local hardware and get 2 ferrules and a piece of copper line the right size and length. Seems like it's about $5.
Ross
