Hydramotor blocking valve
OC4-3D
Hi guys. Taking apart the Hydramotor steering unit from the 1550. Appears to be late production style. I want to remove the blocking valve spool so I can put a new o-ring on the 'plug'. The service manual (I think it's an I&T) says I should be able to just push on the spool and the spring will pop it out. Not so much. There's a little pin driven in the casting (arrow in pic).
Am I missing something?
-C
