jon f mn
My friend has a white 2-85 that is having hydraulic issues. When running the haybine the hyd over heats and makes noise. It also seems to have low pressure at low rpms. Steerimg and brakes work good tho. There is also a pto issue that may or may not be related. The pto pulls good but won't stop completely unless you shut off the engine and restart it. So the question is does it sound like a pump or valve problem? Could the pto valve be leaking and causing the heating and drawing enough oil to cause low pressure at low rpms? I know nothing about these so any help as to where to start would be good. Thanks
