302 sleeve source
Friend has a 950 diesel that they are gone in, I wouldn't overhaul another diesel myself not worth it to me, and usually if they are that wore out the heads are no good to boot. I can't remember where the kit came from on the did one we did about 5 years ago.
I would like to hone a couple gases and re-ring them eventually if time permits and I can get the manifolds fixed.
New ones are not available any where that I am aware of. Unless you can find some NOS ones, Power Bore Sleeves will make you new ones with your pattern. Also FYI 4 inch 44 MH pistons will work in 302 waukesha with no modifications.
