60 and 66 wide fronts?
Olliejunkie
So I have a 60 and a 66 with wide fronts. Neither have the b suffix. I called Floyd's to get build cards and they said the furthest they go back is the supers. I have read the factory wide fronts had a b stamped on them. Is this true? Would mind be a dealer ad on or someone put them on later?
If the 60 came with a wide front from the factory it will have a B stamped in the serial # the 66 wont and yes they culd be dealer add ons
The B is stamped on engine tag if you 66 is a super it should tell you on the build card if it was a factory installed wide front
(quoted from post at 07:43:57 03/26/17) The B is stamped on engine tag if you 66 is a super it should tell you on the build card if it was a factory installed wide front
Thanks. I read somewhere that the 66 were stamped b too.
