I am (hopefully) attaching a scan of my 1850 build card and a scan of the info sheet sent by Floyd County. If you look under
"Q" you can see it says 434. Now if you look at the info sheet it says "Sparky's 1850 Hi Crop". I have an over/under. Any idea
what got messed up?
   Several of us in the HPOCA have been doing extensive research on the Build Cards and will do a seminar at next Winter's HPOCA Meeting, so hang on.   The plate on he lower part of your dash should have 485-22013 on the top line and the serial number followed by 557.  Following are the code numbers on your card and what they mean:
[b:654c4848f0]A 404[/b:654c4848f0] For diesel, adjustable regular tread front made for Oliver (Different # for Canadian & International sales)
[b:654c4848f0]B 008[/b:654c4848f0] diesel engine
[b:654c4848f0]C 557[/b:654c4848f0] Regular speed drive train (the last version, has pinion tie downs)
[b:654c4848f0]D 00[/b:654c4848f0] Not used (belt pulley)
[b:654c4848f0]E 427[/b:654c4848f0] Single speed 540 PTO
[b:654c4848f0]F 430[/b:654c4848f0] Hydra-Electric internal valve, draft control, power steering
[b:654c4848f0]G 047[/b:654c4848f0] 18.4 x 34" 6 ply R1 tires
[b:654c4848f0]H 39[/b:654c4848f0] Cast Iron wheel for 34" rim (either demountable or power adjust)
[b:654c4848f0]I 86[/b:654c4848f0] Rim for 16.9 or 18.4 x 34" tire
[b:654c4848f0]J 00[/b:654c4848f0] None installed - Rear wheel weights
[b:654c4848f0]K 053[/b:654c4848f0] 11.00L x 15 8 ply F2 3 rib
[b:654c4848f0]L 70[/b:654c4848f0] Pressed steel wheel for 11.00L x 15" tire
[b:654c4848f0]M 00[/b:654c4848f0] None installed, Front Wheel rim (only used W/cast iron wheel, yours has Pressed steel)
[b:654c4848f0]N 00[/b:654c4848f0] None installed, front wheel weights
[b:654c4848f0]O 057[/b:654c4848f0] Light package for crown fender mounted lights
[b:654c4848f0]P 062[/b:654c4848f0] Fast coupling hitch with regular drawbar
[b:654c4848f0]Q 434[/b:654c4848f0] Clutch & Over/Under Hydraul for diesel engine
[b:654c4848f0]R 72[/b:654c4848f0] Standard tread Carrier & Axle for 72" - 92 1/2"
[b:654c4848f0]S 022[/b:654c4848f0] Crown type wheel guards, step & platform for Row Crop tractor
[b:654c4848f0]T 052[/b:654c4848f0] Upholstered seat
[b:654c4848f0]U 405[/b:654c4848f0] Power steering, adjustable regular tread, W/Hydraulics, diesel engine
[b:654c4848f0]V 000[/b:654c4848f0] None installed - Rear mounted equipment
[b:654c4848f0]W 201[/b:654c4848f0] For adjustable front, diesel W/O/U drive - Sheet metal, grill, dash, instruments & controls
[b:654c4848f0]X 000[/b:654c4848f0] None installed - front mounted equipment (loader or fork lift)
[b:654c4848f0]Y 000[/b:654c4848f0] None installed - Roll bar or cab
[b:654c4848f0]Z 10[/b:654c4848f0] Two dry charged batteries.
This should answer your question
Where do you get build cards at? I have 1964 550 I'd like to get a card for.
Thanks
This was the code number on my hicrop1850. At that time they did not know what the code number meant so Mary Ann just put on Sparky's hicrop.
