Oliver 6 cylinder Continental engine Info. needed
I have acquired an Oliver 6 cylinder Flathead engine and would like some help to determine the applications the engine can be used for. I think this unit was originally out of a combine. Pictures will be coming in the next day or two. The engine number is: F209 14456. If you have information on Continental engines as used in Oliver applications , please help us out.
Al
It was used in older pull type combines. The self propelled units used the F-226 & F 244 which are similar to what you have only larger and newer.
