Oliver 1650 Ser. No. Question
CWL
Starting to do some work on my new to me 1650 Diesel and have a question on the serial number. Someone has painted over the ID tag below the dash but I can still make out the stamped numbers. I'm just not positive how to read the serial number. The top row of numbers is 265-22088 the bottom row is 178116-452. Is 178116 the serial number? If so and I'm looking at the tractor data website that makes it a 1966 version correct?? I need to get some pictures of it this weekend while the weather is nice and post them.
Thank you for the information. I have the Operator, Parts and Service manuals on order. Might show up today. Should make for some good reading and learning.
HPOCA has been doing research on the Build Card code numbers.   In view of the fact that the 1650 has become a favorite of collectors, I will add some additional information that is on the Serial number plate.
[b:654c4848f0]Specification:[/b:654c4848f0] (top row)
[b:654c4848f0]First three digits:[/b:654c4848f0] 165 through 465 are 1650 tractors, starting at 165 then as changes were made advanced to next number.  565 & 665 are 1655 tractors.
Numbers after the dash: [b:654c4848f0]First#:[/b:654c4848f0]
1=Dual front
2=Adjustable front
3=Single front wheel
4=Wheatland
5=Utility
6=Rice
7=Industrial
8=Mechanical Front wheel drive, AG
9=Mechanical Front drive Industrial.
[b:654c4848f0]Second#:[/b:654c4848f0] 1=Gas engine, 2=Diesel engine & 3=LP engine.  Last three numbers are the combination of all combinations that was installed on the production line.   Those number records no longer exist, there was almost 999 combinations.
[b:654c4848f0]Last three in Serial Number (bottom row):[/b:654c4848f0] Are numbers for the powertrain for a 1650.
452= standard speed 2 wheel drive Row Crop
456=High speed 2 wheel drive Row Crop & High speed Wheatland/Ricefield
468=Standard speed Wheatland / Ricefield
461=Standard speed Mechanical Front Drive
465=High speed Mechanical Front Drive
480=Hydraulic front drive.
The complete listing of the code numbers on the build cards will not be published, available through the Floyd County Museum.
