perkins from massey combine
Jerry He
What all will I need to put a Perkins from a Massey combine in an 1850 gas tractor?
I would like to have an 1850 diesel but can not find one that is not total junk.
You'll need the old engine out of the 1850. You'll pretty much have to strip the combine engine down to just the block and head. You need the oil pan,front cover,water pump,oil pump and plumbing,oil filter base,tappet cover,one side cover,injector lines,linkage to and on the injector pump,oil cooler,intake and exhaust manifolds,probably more,but that's what comes to mind right now.
