1655 voltage regulator again
I think this answers my question.
I wired it like the GM diagram except I left off the resistance wire on terminal 4. I figured it was an automobile accessory wire.Should I have run that wire and why?
Take the cover off. The regulator you need has one unit under the cover. I think the regulator you are trying to use has 2 units under the cover. Look at your 1650 wiring diagram, it has 2 wires!
