1550 HPD clutch pack
OC4-3D
Anybody know what the minimum thickness is for the plates in a Hydra-Power Drive clutch? Service manual I have says .066-.072 for both, but the plates with facing are measuring about .112. Everything in the HPD seems in good shape, but it used to shudder in direct under load, so I'm double-checking dimensions before I reassemble.
I will need the serial number of the Hydra-Power drive. There were 2 styles of clutch plates used. My e-mail should be open.
