Butch...Mn
I have continual problems with the hyd oil turning milky in this tractor. I have changed the oil probably 4 or 5 times and it will be milky again in a couple of days. The tractor sits inside when not in use. The oil gets so bad that the oil filter/screen just ahead of the pump almost completely stops the flow of oil to suction side of pump. Is this merely condensation or is something else going on? Is there a solution to this problem? This tractors main use is pulling a box scraper around a rather large farm yard to blade the gravel. Would I dare add some acetone to the oil to absorb the moisture or would that create more problems than I already have? Other than this, it is a great little tractor around the yard!!
