1655 Oliver loader valve install.
J Bruns
Hello was wondering what difference it would make to hook up a two port loader valve return to the 3/4 drain plug instead of the 1/2 port above that they recommend.
Thanks
Yeah I have all that done I was being told that I have to put a power beyond valve on this tractor to make it work properly. I was just wondering if I could hook it up to the two 1/2" ports and it make it work right. I have a two port loader valve not a 3 port. Thanks
Is this the schematic you're using? I know what you're saying,I just don't know if it makes a difference. Why do you want to do it? Can't you get the right plug out or something?
Yeah I can get all of them out I was trying to make it work with just running the two port valve Hooked to the two 1/2" ports and still have it operate as best it could.
Ok that's what I'm going to do. The reason I was asking all this is I didn't know if it would make a big difference to buy the power beyond plug and make it a three port valve. Reason being that seems like a lot of fluid to return to a 1/2" port when your lowering the loader. Thanks for the input
That half inch port should be plenty. I have an open center valve on my loader,but I have it plugged in to the inside remote and have the lever blocked back,so all of my oil is going through the ball in the pioneer coupler.
