Oliver Super 88 bellhousing removal
Have a super 88 that I need to get to clutch/pressure plate. Finding conflicting reports as to whether or not I can pull bell housing without pulling engine on a tractor that has belt pulley drive like mine. Can someone confirm I can pull my bell housing with engine in chassis? Thanks!
I'm surprised this is unanswered. If you pull the 4 engine mount bolts and slide the engine forward a tad you can wiggle it out of there. Don't scoot it up any further than necessary. gm
If the there is no belt pulley gear box and no two speed, you can wiggle the bell housing out with the engine in place. I have done it a couple of times.
Rich
