2150 progress pictures
Here is the latest 2150 pictures. Getting close to done on the rear section except for fenders and hubs.
Looks very nice, look forward to seeing it completed. FYI our 2150 is original paint and has white rear hubs, but it was the last one off of the line so maybe some of them were green, but ours isn't.
These hubs were green when I bought the tractor. This tractor was built 6-12-69, your's should have been built 6-13- 69, I think. When I blasted the clamp hubs I saw no trace of white paint. I believe this tractor was half- assed repainted some time ago. I can't believe they would have blasted the hubs to repaint them the way they half-assed repaired things on this tractor. Does your have the plant. rear end or the regular like mine? Your 1855's look great. Are you going to take them to Rantoul this fall?
Ours has the bar axles like yours. I will look at them closer today and see if I can see any green. Our Oliver's probably won't be at ranoul, Portland Indiana has a large show the same weekend and they are featuring Oliver, so they will probabaly go there. I will prob bring a few deeres over to rantoul though.
Very nice restoration, have never seen a 2150, did they use the same rear half as the 1955 oliver? Axle housings look to be the same as my 1955.
I checked our hubs and they have no green under the white, so I'm not sure what's correct, I'm sure both yours and ours left the factory with the same color since they were built one day apart.
