Eversacres
New User
I have an Oliver 1800 checkerboard tractor with a rockshaft off of an Oliver 1850. Lots of hydraulic pressure, but all the oil leaks into the rearend after a few hours, and the 3 point lever will not stay where you put it.( it goes back to the raised position when you let go of it) And as soon as you shut the tractor off the three-point drops all the way down. Does anyone know how to fix this, or where buy a good rockshaft?? I would like to get one off of an Oliver 1800, but if I could find one off an 1850 that works, that would be fine too! Hy-tran oil gets costly and draining excess oil off before using the tractor is getting old!! Thanks!!!
