I'm assembling an 880 gas engine. Today while installing the oil pump I can't seem to get the distributor drive slot perfectly straight (parallel to cam). I believe my problem might actually be too much wear on the back side of the cam gear. I had noticed that earlier when I installed the camshaft that the front face of the cam gear was not flush with the front of the crank gear. It was set back closer to the block, maybe 3/32". when I pull the cam forward to get both gears flush, then my slot is straight. Can I install a shim washer behind the gear? Or should I start looking for a different cam gear? Or just put it together and see if there is enough twist in the distributor to make it work? I wonder if the slight misalignment will affect the contact with the tappets. I'd appreciate hearing any thoughts or opinions. thanks JH
