550 Oliver clutch replacement
Jona
I have two questions does anyone have a video as to how to fix the clutch on a 550 oliver number two does anybody have a video on how to fix the clutch is it easier to take out the motor or to split the tractor also I am looking for A checkerboard grill and an air cleaner and a set of flat top fenders that I'd like to put on this tractor
It's a easy split. Just put some wooden blocks wedged each side of the front axle to hold the motor straight. Put a jack under the transmission another under the front have, take the bolts out of the center in a Z split, and roll the rear back. I helped my neighbor do his, and it sure didn't take long.
I think if you search You Tube,you'll find a video of the Z split that Jack's talking about. Simple spilt.
