1365 hydraulic pump kit
Have you got your old pump apart yet? in my experience those aluminum body pumps usually aren't worth re-sealing. You hay very well find that the housing is scored once apart (where the gears turn). New pump from a hydraulic shop run from $250 - $400 or so depending on where you live. May even consider a slight GPM upgrade while your at it for the same money. Had one on a white 700 last winter that I thought just needed seals, got it apart and it was trashed. Interesting story on that one as well, It was the front seal that was gone and it was sucking engine oil past the seal and putting it in the rear end at an alarming rate. Didn't know where the oil was going until it came out the rear end vent.
