1365 pump kit question
It doesn't leak it just does not pump any more. Only 500 psi at the remotes at 2000rpm and the 3pt arms will barely raise themselves. So i figured its time for a rebuild, which now I realize this is a seal kit not a rebuild kit. I guess Ill be ordering a new pump. Which way does the hydraulic pump spin? Counter clockwise or clockwise.
Thanks for your input.
You can get a new pump off ebay pretty cheap and if the body of your pump is worn like most I've seen the rebuild kit won't do you any good,might want to clean the intake strainer
before you do anything if you haven't done it already.
