Oliver 1850 transmission question
Hydraulic idler gear w/ 43 teeth. Book shows part# 159023A & 162450A. It appears they are both good part numbers. Is there a difference or do they sub? The 1750 book only shows #162450A.
Thanks, Dave
Been scratching my head on this one. Are the shafts the same size for both gears? Maybe a different shaft part number and different bearing numbers?
I just did a quick check. 159 023A is no longer in the system. What is the serial number of your 1850? 162v450A is a good number.
