Buda rear seal
Mike(NEOhio)
Location
Newbury, Ohio
I'm assembling the 230 gas with the press-in rear seal retainer (pic 1). How should the rubber ring go in? It has a groove on the ID (pic 2). Is that groove supposed to go on the small lip of the retainer or between the lip and rear plate (pic 3). No instruction was in the gasket kit. I think it should be like 3 but not really sure. Can anybody help?
Thanks, Red. That's the way I thought it should go. Gasket kit had both seals but no new seal ring for the bolt-on. That and the wear sleeve is why I'm using this one. That ring will take a lot of stretch to go on.
Yes it has to stretch a lot any problems let me know I have put alot of these together this is mike lepard I think we've talked before
You know of any 50 diesel engines for sale. What Gleaner engines will fit the 50. If I had a 40 diesel engine I would sneak it in my 50.
