Hi Folks - Tried to revive an old post on the same topic but I wasn't allowed..
because I have a similar problem and looking for some insight. On my 1655 Diesel Cockshutt, (only had the tractor for about 3 years), this problem is steadily getting worse.. I have not done anything
except check and add fluid. (The tractor does not get hardly any hours at all, except snow-blowing season) When the tractor is cold, hydraulics work very well (3PH, Remotes and Steering), but as the tractor
warms up from working it, I need to rev the RPMs up very high to get the 3PH to lift or the remotes to work. I'm pretty sure I'm going to need to bust into the hydraulic system, (which is not in my comfort
level) so if anyone has any specific ideas or common causes that I should be looking for, I would be greatly appreciative..
Thanks
PS - I am using HyTran fluid. (Other thread's post mentioned measuring oil temperature... What should the temperature be? ...and if too hot, what might cause this?)
Thanks
