Valve seals ?
There are several types of Valve Seals.. Sounds like (Maybe) yours could have Perfect Circle Teflon seals installed..?
They slip over the end of the Valve Guide after the Guide is milled with a special tool.
Most either have none and many folks do at least install Umbrella Seals on the Intake Valve guides..
Perfect Circle valve seals were standard equipment on those engines on the intake guides. The guides are machined for those seals. I may even have a set around here yet.
