Oliver 1365 loader mounts and set for 30's
I need to know if I can set the wheels to fit down 30 inch rows and have the loader mounts. It looks like I
need to in bolt the rim from the center and then put the rim on the inside of the center to make 60 inches
wide. But it looks like it will be close to the loader brackets.
Thanks for the input.
What do you have for a loader? This one's a 1524. Tires are in pretty narrow. They're close to the frame,but clear alright. My big issue is that the threads stripped in the axle housings. I drilled them out bigger,retapped them to the next size bigger and the bottom one is stripped again. I got some big U bolts the other day. 5/8ths by 6 and 3/4. Gonna try clamping right around the housing and tack welding the bolt in the loader frame to keep it from twisting. I hope I don't fowl up the axle housing.
1510 and 1514 appear to stand up higher. I have to think they mount the same way otherwise.
Cool. Now all I have to down is figure out a way to make it somewhat of a quick attach. Thanks for the input and great looking 1365.
Somebody put Pioneer couplers on the hoses to the bucket cylinders on mine. Unplug those and pull the pins,hang it up from something,back away and chain the cylinders up to the frame. Only problem is,when it raises,the hoses move and twist the couplers,so the O-rings in them are starting to leak.
