1850 no hydraulics
1070BK
Getting to this problem that happened this past summer. Lost my hydraulics on both remotes. The levers basically flop back and forth without doing anything. tried different hose tips but don't think that's the problem. Could there be something disconnected? Doing some research before I tear into it.
It is a diesel. Steering works fine. I believe the three point works. I never use it. PTO works fine but I need to adjust it again. It doesn't shut off very well. The latch is worn.
If levers just flop back and forth, something has broke or come loose. It could be the bolts on the lever arms inside the hydraulic housing are loose.You'll probably need to remove the top cover.
