88 with cummins 5.9?
cummins guy
New User
looking into buying a oliver 88 row crop for 1500$ no motor in good shape tho..
I have 2 12 valve in stock.. A ve 130hp and a ppumped 210...
How much power can it handle?
Big job to fit in?
Trans?
No turbo?
Cummins guy ,There is a Super 88 with 5.9 in it and he has posted on here before. Just put 88 with cummins 5.9 in the search box.
I did one before just a few years ago it depends on what you want to do with it we set this one up for pulling it weighted in at 4200 with the driver on it if you are looking to farm with it I would change a few things to make it heavier e mail me and I can help if you would like
I think Greg is referring to to the Cummins I installed in a S88, I can try to answer any questions you have or send pics. Do you have a plasma cutter? it will make quick work of the cast tub to make room for the bigger oil pan. As far as the trans it should handle those hp numbers, one of the weak points is the rear bearing support for the top shaft.
