Perkins 354 Question
Hey guys,
hoping someone could shed some light on the differences between the turbocharged and non-turbocharged Perkins 354 Diesel engines.
Thanks
What kind of light are you talking about? Are you comparing say 2 Dot 1 engines, two dot 4 engines or what here? You can have major differences between non turbo engines as well as turbocharged engines internally.
I guess I could have made this simpler. Oliver 1850 vs a White 2-105, how different are their respective engines. Can you bolt the turbo onto the Oliver and be alright or am I asking for trouble.
Well it has been done, But there are a lot of differences between the 1850 no dot engine and both the 2-105 dot one engine and the later dot four engines. Were you using the Perkins manifold and turbo? They bolt up different because the head was changed. How much horse power are you looking for and to play with or as a regular farm tractor. @-105 also has a stronger final drive.
