Rusty Knuckles
How hard would it be to install a 2-70 283 diesel into a 1800A that was a gas. Could I use the 1800 tank and just ad a return port?
Will the 1800 flywheel fit / work? Will the PTO shaft still work?
Will need a different air cleaner. Will the radiator be enough? The exhaust ports look to line up close.
I have a tractor with no engine and found this 2-70 engine was wondering if they will work together. Used for small farm work.
[i:596a00e8e9]Or does someone have another diesel engine taking up space.[/i:596a00e8e9]
