Oliver 60 loose crank pulley
Olliejunkie
I just pulled the fan belt on my 60. I noticed that the crank pulley rotates a little. I haven't tried to tighten it yet. I don't even know if I can without removing the radiator. Has anyone ran into this?
Is the whole pulley turning or just the front half? They're slotted so the front half turns inside the back half to make it wider or narrower. That's how you tighten the belt.
(quoted from post at 05:25:21 12/29/16) I have a77 that is that way we run it But I am going to put another pulley on this winter
Thanks Bret. Think I will run it for awhile. I'm waiting on a belt and oil filter. Might take the radiator off soon but I have plenty of other things to do first.
