White 2-105 muffler angle?
Fortyhorse
New User
Sorry to ask such a dumb question, but
is the muffler supposed to be tilted
slightly back on the 2-105 tractors or
are the replacement mufflers just not
made quite right. Thanks bryan
Mine's straight. It leaned back when I caught a low limb with it,but I loosened the clamp and tipped it back straight.
Kind of hard to tell but the muffler is pretty much straight.
Thanks, I must have something wrong, the turbo manifold seems to be tipped rearward and there is no gap in the front of the muffler hole in the hood, so I can't just push the muffler ahead. Not sure I can adjust the hood ahead any more. Maybe I will need to heat the bottom of the muffler to get it straight.
When I was hauling fuel to the farmers I saw a lot of White tractors with the muffler leaning to the rear. Back then they were new. I'm sure they came that way.
Thanks, I must have something wrong, the turbo manifold seems to be tipped rearward and there is no gap in the front of the muffler hole in the hood.
Question on that. Does your hood have a round hole of teardrop shaped? They should be teardrop with the smaller part toward the front to accommodate the small tube from the muffler to the air cleaner.
I just don't understand how the muffler can be straight when the whole manifold doesn't run at the same angle as the hood.
It's not a dumb question. As your last post this AM says, how can the muffler be straight when the manifold (and engine) tilts back. IT CAN'T !!!! Oliver and White with their sloping power trains have to have a tilted muffler if it square with the manifold. The muffler on my 2-105 slopes back at the same angle as the front glass on the cab. What makes it seem even more tilted is the fact that the hoods slope down toward the front on the 105's. Maybe Oliver people just have a different definition of straight.
