880 air cleaner
Dblair
I'm looking for a 880 air cleaner . if anyone has one they would sell or knows where I might get one contact me . 804-243-4158 thanks .
A Super 88 used a KS 406D. This air cleaner was also used on early 1600 gas tractors. I don't have my 880 parts book here but they look the same.
thanks John , I appreciate the information , I changed my 770 puller a little in the head with valves and such and the dyno says I'm losing a lot of hp in the air cleaner . 5 hp and that's a lot to a small hp puller .
one of the guys stepped up and is sending me an air cleaner. what do you think ? can you beat these guys ?
Are you going to pull the 880 and does your club require the air cleaner? If so you can gut it and put a filter on top and get good results. Chuck
I wanted it to look original don't know if I can yet . may have to gut it and put a cone shaped filter in it or like you suggested on top . thanks Chuck, for the input .
Your'e welcome Dave, my 660 is gutted and looks stock except for the K&N filter on the top. With a little work you can put under the hood and stick the original stack on top of it. Chuck
