145 Workhorse
Recently had my Marvel Schebler carburater rebuilt. I can not get the engine to run smooth at high idle speed unless the choke is wide open. Without choke, the engine continues to surge. The high idle screw is wide open. Or if taken out completely, the engine runs better, little to no surging.
I believe the engine is not getting enough gas. Steady flow from the tank filter. What is the proper float height? Is a jet in the carb worn? I am baffled.
Electrical system seems to be good. Engine does not miss and starts good.
