clutch slipping?
Kccca
Merry Christmas to all from Central Kentucky. Don't miss the snow a bit.
One question: How do you tell the difference between the clutch disk slipping and the O/U unit going bad on a White 2-105?
Underdrive is mechanical through a sprag clutch. Direct and overdrive have hydraulic clutches. I would check clutch pressures for the O/U unit. How much clutch free petal do you have?
