1550 axle seals
Mike(NEOhio)
Location
Newbury, Ohio
I need to replace a rear axle seal. Item 6 in the parts book is named only "washer", K703-A outside of the seal. Is it a felt washer or steel? I can't tear it down just now but I want to get the parts ready. If it's felt can it be reused and are they still available?
Mike: Unless your tractor has extra long axles the part number for the seal is a 160 433-A The part you mentioned is a felt seal. Check your axle preload before you tear it apart.
